draybook Posted August 14, 2006 Share Posted August 14, 2006 I'm having some trouble with my distributor. I'm driving a 91 CRX HF, with a ZC motor. About once a day, it will either cut off while driving ir not start after having sat for a while. I got the car from my brother in law and he's had that problem for a while. He said something about the distributor "popping" every now and then. Usually, if I give the wires a good reseating it will come back but sometimes it will take about 5-10 mintes to start back up Now, if this is a simple fix then good, if not, what type of distributor will I need to get? Can I get the stock one for that year/model or so I need one from an Integra of the same range? Thanks. Link to comment Share on other sites More sharing options...
cranny Posted August 15, 2006 Share Posted August 15, 2006 you need the distributor for that engine and wiring harness in the car. not that another type of dizzy wouldnt bolt on , but the plugs and/or pinouts are different. you got an engine light? Link to comment Share on other sites More sharing options...
draybook Posted August 15, 2006 Author Share Posted August 15, 2006 you need the distributor for that engine and wiring harness in the car. not that another type of dizzy wouldnt bolt on , but the plugs and/or pinouts are different. you got an engine light? I found out that I need the distributor from an 89 Integra. Link to comment Share on other sites More sharing options...
