lilcrxthatculd Posted August 10, 2006 Share Posted August 10, 2006 i have a question, the other day i was driving my rex and i was turning as i downshifted from 2nd to 1st my car cut off, it cranked right back up but a pgm fi light came on. wat does that light mean? the car was also low in fuel would that have something to do w/ it. i just purchased this car and that was the 1st time it was low in fuel its a 87 si Link to comment Share on other sites More sharing options...
Creeman Posted August 10, 2006 Share Posted August 10, 2006 You have fuel injection which means your fuel is pressurized and when you run low on fuel turning a corner can cause you to lose pressure and the engine will die. The pickup point in the gas tank has lost fuel momentarily until the car straightens out again. I hope this helps. Link to comment Share on other sites More sharing options...
lilcrxthatculd Posted August 10, 2006 Author Share Posted August 10, 2006 wuld that cause that light to come on? it comes on every once and a while now Link to comment Share on other sites More sharing options...
Kastigir Posted August 11, 2006 Share Posted August 11, 2006 Typically when that light comes on it stores a trouble code in the ECU. However, my 87 Rex PGM-FI light came on once, and no code stored, so who knows. Link to comment Share on other sites More sharing options...
lilcrxthatculd Posted August 11, 2006 Author Share Posted August 11, 2006 alright thanks Link to comment Share on other sites More sharing options...
