jagalag Posted June 24, 2006 Share Posted June 24, 2006 Well.... I just got this no-name filter from Deathzone auto parts and the guy there couldn't explain to me what these three washers in the box were for... There are two large ones and one small one. In my Haynes manual it says that the two big ones are for the banjo bolt that secures the filter on the topside.... I don't know what to do with the smaller one though... I don't want to become a moving fire hazard so any help anyone can give is greatly appreciated. Thanks. Link to comment Share on other sites More sharing options...
Kastigir Posted June 24, 2006 Share Posted June 24, 2006 There should be a bolt on top of one of the banjo bolts. It's used to check for fuel pressure in diagnosing starting problems. The washer most likely goes there. Link to comment Share on other sites More sharing options...
jagalag Posted June 24, 2006 Author Share Posted June 24, 2006 Are you 100% sure about this??? Link to comment Share on other sites More sharing options...
Kastigir Posted June 25, 2006 Share Posted June 25, 2006 Are you 100% sure about this??? No, but have you pulled that bolt and found a washer under there? Link to comment Share on other sites More sharing options...
phillyhonda800 Posted June 27, 2006 Share Posted June 27, 2006 dude! my advice! take it to ur dealer. it'll only cost u $45.00 to have replaced but the job will be done correctly and u won't blow up. jiffy lube wouldn't change my fuel filter and they specialize in this area. there's a purpose for the third small washer. good luck! Link to comment Share on other sites More sharing options...
