import142 Posted May 3, 2006 Share Posted May 3, 2006 well i have a problem with my subs. sometimes when i turn my car on there is a constant pop pop pop from my subs. when i added gain the pops got louder and i checked all the wireing and none of it is touching. i checked the rca cables and they are fine and im not sure whats goin on. it usually stops after i start my car and get going but sometimes it still goes until i turn my deck louder than the poping. Link to comment Share on other sites More sharing options...
REDLINEperformance Posted May 16, 2006 Share Posted May 16, 2006 That popping you hear is called "road noise". It could be many things. Bad ground, ground wire too long, amp gain is all the way up, bad rca's, bad rca turminal on amp or head unit. Try changing your ground position and sand the area till it shows metal. Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted May 20, 2006 Share Posted May 20, 2006 I also hear if your Lead wire is too close to your RCAs you'll get a popping noise. Link to comment Share on other sites More sharing options...
cranny Posted May 20, 2006 Share Posted May 20, 2006 negative on popping cause of power being next to rca's. Link to comment Share on other sites More sharing options...
2005civic Posted July 23, 2006 Share Posted July 23, 2006 check the ground nera your deck, my subs were doin that too till i figured out i blew some fuse inside my old deck. Link to comment Share on other sites More sharing options...
blackdelsol Posted July 23, 2006 Share Posted July 23, 2006 I think they figured it out by now. look at the dates before you post. Link to comment Share on other sites More sharing options...
