willthiswork89 Posted May 1, 2006 Share Posted May 1, 2006 my clutch slave cylinder blew and i bought the part and i want to know if somebody can tell me how to do it, possibly a tutorial thanks. Link to comment Share on other sites More sharing options...
blackdelsol Posted May 1, 2006 Share Posted May 1, 2006 that has got to be the easiest thing i've ever replaced on my car. you get a flare nut wrench prefferably ( like a box end, but it has a small opening so you can slip the clutch line through it) and remove the drain plug: then you unbolt the two small bolts hoding on the slave cylindar and just put the new one on in reverse of those instructions. make sure you bleed the clutch lines afterward to remove any air in the lines. it takes two people. connect a hose to the end of the drain plug and have one person depress the clutch. put the flare nut wrench on the drain plug and loosen it. when fluid/bubbles stop flowing tighten the bolt and then have them release the clutch pedal. repeat until no more air comes out. Link to comment Share on other sites More sharing options...
blackdelsol Posted May 1, 2006 Share Posted May 1, 2006 Here is a flare nut wrench. you will probably need a 10mm one: Link to comment Share on other sites More sharing options...
Prelude1897 Posted May 2, 2006 Share Posted May 2, 2006 since you're changing the slave cyclinder, I'd advise changing the master cyclinder as well... Link to comment Share on other sites More sharing options...
blackdelsol Posted May 2, 2006 Share Posted May 2, 2006 I wouldn't. they're completely separate and the slave cylindar goes out far more often. and the master cylindars are way more expensive. Link to comment Share on other sites More sharing options...
willthiswork89 Posted May 2, 2006 Author Share Posted May 2, 2006 actually the master cylinder blew too, fluid all inside my firewall on my floor boards, it sucks dude, the master is like 68 bucks, they want like 200 to install it but i might just do it my self, it seems simple enough. i wonder hat caused them both to blow? guess ill never know lol. thanks so much for the help guys Link to comment Share on other sites More sharing options...
86accordlx Posted May 2, 2006 Share Posted May 2, 2006 I have a 1986 honda accord LX (217000k's on it) , should i give car to buyer for value of 500$, give 1000 cash, for a 1992 honda accord LX ? (345000 k's on it)?? i have a friend who will do this for me ? is it worth it ?? Link to comment Share on other sites More sharing options...
blackdelsol Posted May 2, 2006 Share Posted May 2, 2006 your welcome '89 Link to comment Share on other sites More sharing options...
willthiswork89 Posted May 2, 2006 Author Share Posted May 2, 2006 86 have ou went to www.kbb.com and checked the price? i will ellyou woth value of it, and he wth value ofthe car you lookng to buy Link to comment Share on other sites More sharing options...
cranny Posted May 2, 2006 Share Posted May 2, 2006 if you got fluid everywhere , im inclined to say maybe you got a busted line , and your clutch parts might still be good. Link to comment Share on other sites More sharing options...
willthiswork89 Posted May 3, 2006 Author Share Posted May 3, 2006 no i looked at the cylinders and they werre dripping through the rubber dust boot all over, so it was the cylinders not any lines Link to comment Share on other sites More sharing options...
cranny Posted May 3, 2006 Share Posted May 3, 2006 ok i got ya. not a hard job man. do it up yourself dont be scared. Link to comment Share on other sites More sharing options...
