farmerboyalex527 Posted March 18, 2006 Share Posted March 18, 2006 As soon as I start driving my 96 Prelude the ABS pump comes on for about 10 seconds ( I can hear it whine) and then the ABS system shuts down and the ABS light comes on in the dash. I checked the wheel sensors and they all work. I also removed the relay that controls the ABS pump and used a jumper wire to manually make the pump operate and with that opened the bleed screw on the pump. I can't even get brake fluid to come out of there , it should pump out under pressure but does not. Any Ideas? Link to comment Share on other sites More sharing options...
SexyH22 Posted March 18, 2006 Share Posted March 18, 2006 is there any fluid in there? Link to comment Share on other sites More sharing options...
farmerboyalex527 Posted March 18, 2006 Author Share Posted March 18, 2006 As soon as I start driving my 96 Prelude the ABS pump comes on for about 10 seconds ( I can hear it whine) and then the ABS system shuts down and the ABS light comes on in the dash. I checked the wheel sensors and they all work. I also removed the relay that controls the ABS pump and used a jumper wire to manually make the pump operate and with that opened the bleed screw on the pump. I can't even get brake fluid to come out of there , it should pump out under pressure but does not. Any Ideas? Link to comment Share on other sites More sharing options...
farmerboyalex527 Posted March 18, 2006 Author Share Posted March 18, 2006 As soon as I start driving my 96 Prelude the ABS pump comes on for about 10 seconds ( I can hear it whine) and then the ABS system shuts down and the ABS light comes on in the dash. I checked the wheel sensors and they all work. I also removed the relay that controls the ABS pump and used a jumper wire to manually make the pump operate and with that opened the bleed screw on the pump. I can't even get brake fluid to come out of there , it should pump out under pressure but does not. Any Ideas? The resevoir is above the pump and is full Link to comment Share on other sites More sharing options...
SexyH22 Posted March 18, 2006 Share Posted March 18, 2006 yeah thats a good way to get help..... nowhere in there does it say that you have checked it for fluid Link to comment Share on other sites More sharing options...
