rcl4668 Posted September 12, 2005 Share Posted September 12, 2005 We will be receiving a 2006 Honda Odyssey Touring minivan in the next few days. The car is equipped with the Michelin PAX runflat system which entails a special rim, plastic ring mounted inside the tire and a special, all-season tire. The system also has a tire pressure monitoring system. The monitor does double duty as the valve stem on the tire. I would like to mount a separate set of rims and snow/ice tires for the winter months. Questions: (1) Has anyone done this on their Odyssey without any ill effects? (2) Is there a way to retain the tire pressure monitoring feature of the stock tires (for example, by buying four new tire pressure sensors and having them mounted on the aftermarket rims?) and (3) If not, I have read an article online that says Michelin was working on a PAX tire/wheel system that had snow tires instead of all seasons -- anyone hear about that? Thanks in advance for any input or help you can provide. /Rich Link to comment Share on other sites More sharing options...
MavRangerVC Posted September 22, 2005 Share Posted September 22, 2005 as long as you buy 4 new sensors and they are calibrated for the computer in your van you can use both sets of wheels Link to comment Share on other sites More sharing options...
