Carsnob Posted September 9, 2005 Share Posted September 9, 2005 My wife has a 98 accord EX sedan with the 4 cyl. Well her throttle body was sticking a little and driving me nuts when I had to drive it sooo on Monday while I was off I decided I was gonna fix it All went good. I unhooked everything from it where I could get to it good (all the sensors and hoses). Spilled a little gas when I unhooked that line but other than that the process went ok. What I did was spray some solvent (engine degreaser) on it and then wipe away what I could with a rag and then the really tough stuff I scraped off with a flathead screwdriver. I reattached everything and fired it up. Well it idled like garbage. I thought it was just a little air in the fuel line, but figured after it ran a second it would smooth out. WRONG!!! And when I would give it some gas it would cut out studder and resume idling like poo or stall. Well, I checked all my connections again and everything seems to be in order. So I did a little reading and it seemed to be problem with the MAP sensor. So I jump on ebay and get a "new" one for $28. It came in last night. I tried to crank the car before I put the new MAP on just for comparison. Car wouldn't crank. I put the new MAP on and car wouldn't crank. I unhooked the battery for about 15 min and tried again. Finally got it to crank after a few tries and it did idle better, but not much. Same simptoms Also, after revving it a few times (untill it would cut out around 1500rpm) I could smell gas. I don't have a clue and my wife is getting tired of driving the 5.0 REAL fast. PLEASE HELP ME!!! Link to comment Share on other sites More sharing options...
Carsnob Posted September 12, 2005 Author Share Posted September 12, 2005 Well, I was finally able to get ahold of a friend of mine that used to be a honda tech that lives down on the Mississippi Gulf Coast. Apparently, I had the TPS and MAP cables backwards. 'oh!: Swapped them when I got home and it cranked right up and purred like a kitten. Link to comment Share on other sites More sharing options...
