xxpnoy_pimpxx Posted August 6, 2005 Share Posted August 6, 2005 I have seen pictures of Del sols with integra and civic (eg) front ends and i was wondering if it is a straight forward bolt on converion. Link to comment Share on other sites More sharing options...
Humphries Posted August 6, 2005 Share Posted August 6, 2005 there is a lot of modification. theres even a lot of modification just to make a 5th gen civic to 7th gen civic conversion. i havent done it but maybe someone else has. Link to comment Share on other sites More sharing options...
xxpnoy_pimpxx Posted August 6, 2005 Author Share Posted August 6, 2005 What type of modifications are we talkin about??? Link to comment Share on other sites More sharing options...
SexyH22 Posted August 6, 2005 Share Posted August 6, 2005 if you dont have experience w/ body work, you probably cant do it. Link to comment Share on other sites More sharing options...
delsolgst9397 Posted August 6, 2005 Share Posted August 6, 2005 Just looking for someone who has done one i allready have the civic rad support in headlight buckets. mounts under headlights to hold front bumper on both fiberglass fenders cut civic and del sol fiberglass hoods. problem comes along with the hood hinges what did people use on it the del sol ones wont line up with the mounts to the body and the civic 98 ones the holes are closer together i was woundering if a 92 - 95 civic s would work ...any help thanks Link to comment Share on other sites More sharing options...
xxpnoy_pimpxx Posted August 6, 2005 Author Share Posted August 6, 2005 wut about the integra converion is that harder????? Link to comment Share on other sites More sharing options...
delsolgst9397 Posted August 6, 2005 Share Posted August 6, 2005 integra front would be cool also but working for honda i get the parts at cost so i got the lights rad suppert etc from them and started it but i think i ll use the del sol hood and just fiberglass the 98 front half onto that one since i have the factory hood. fiberglass to fiberglass wont be to bad Link to comment Share on other sites More sharing options...
xxpnoy_pimpxx Posted August 7, 2005 Author Share Posted August 7, 2005 so if i wanted to do an EG front end conersion i would need to do more than just get some fenders a hood a front bumper and some lights and just bolt it on?????? Link to comment Share on other sites More sharing options...
delsolgst9397 Posted August 7, 2005 Share Posted August 7, 2005 Correct right now i have the civic hood which im having trouble finding out what hood hinges to use or i might need to modify the ones i have. the front fenders, headlights. the radiator support if going to do this get the whole front bulkhead which includes the front rad support and buckets can get all seperate but will have to do more welding this way, will need the brackets that go under the headlights for both sides that the bumper slides into, the front reinforcement bar you might be able to use the del sols but i didnt have mine after putting on my aftermarket bumper years ago it wouldnt fit on with it , so tossed it years ago. under car splash shield for the civic also to keep front bumper from flapping undernieth if using factory bumper hope i explained this as much as possible will be posting pics of progress and will help out with questions as needed ... Link to comment Share on other sites More sharing options...
