CivicPhreak Posted July 22, 2005 Share Posted July 22, 2005 Ok i got a 92 civic si hb and im tryin to figure out what motor i should put in it im dont wana go all out and spend alot of money so im thinking ls b18 non-vtec just a simple swap i know that it will bolt on as far as the engine and tranny are involved but i need to know if the d16z6 ecu and wireing harness will work for the swap and if not would do i need to do and if someone out there has a guide on a swap or a list of crap i need to do te swap from a d16z6 to a ls b18 please let me know thank you.. Link to comment Share on other sites More sharing options...
honde luvr Posted July 23, 2005 Share Posted July 23, 2005 you defenitly need a wiring harnest and motor mounts,ecu,maybe linkages, and a few other things Link to comment Share on other sites More sharing options...
CivicPhreak Posted July 23, 2005 Author Share Posted July 23, 2005 are you sure b/c i was told you could keep the stock harness and just get a b18ecu and it will plug right up any other info would be nice thank you Link to comment Share on other sites More sharing options...
Kastigir Posted July 23, 2005 Share Posted July 23, 2005 For a B series non VTEC swap, you can use the existing wiring harness, but you'll have to swap some of the pins around in it. There was a good writeup about a B series, non VTEC swap in either Honda Tuning, or Sport Compact Car. It's what got me thinking about a B18A/B swap. If I come across it, I will post the relevant info. Link to comment Share on other sites More sharing options...
CivicPhreak Posted July 24, 2005 Author Share Posted July 24, 2005 Thanks any info would be sweet Link to comment Share on other sites More sharing options...
SexyH22 Posted July 24, 2005 Share Posted July 24, 2005 why are you swapping a new motor into it? Link to comment Share on other sites More sharing options...
sL33PeR Posted August 10, 2005 Share Posted August 10, 2005 Yea, im tryin to find out teh same info as civicphreak. Mine is a 1.5 non-vtec. If anyone could help us out on a b18 swap that would be teh $h!t. Link to comment Share on other sites More sharing options...
