w00die Posted July 12, 2005 Share Posted July 12, 2005 all the fans start up when i press the a/c button and i just had the guy charge it with the r12 alternative (hotshot) and he put enough to pass the sensor and we think it might be a relay problem does anyone know where the compressor relay is? The clutch dopesn't engage or even click when i hit the a/c button. Also what is the limit that the sensor is set on for the amount of refrigerant to be charged for the compressor to switch on just in case he isn't filling it up enough. And if anyone has any other suggestions it would help, everything is hooked up correctly it looks like and no leaks. Thanx Link to comment Share on other sites More sharing options...
