Gringing/Rattle noise when AC turned on!!!
Vlad Stepanov
Hey guys,
I have an 05 Accord V6. Whenever the AC is turned on, a sound comes from around the steering pump. It sounds like a thin like grinding / rattling noise. It also sounds like a bearing is wearing out. Any ideas? I'm sure this issue has been mentioned before and some guys may have some info. The car runs perfect. I plan on keeping it for a long time.
Thank you!
If it is coming from under the hood and not under the dash I would check the AC compressor, the AC clutch or the bearings in any pulleys on the AC belt routing.
