92civichatch Posted March 13, 2008 Share Posted March 13, 2008 I really need help i can not find a wiring schematic for my 92 civic i just put in a d16z6 and i don't know where to wire up the VETC solenoid and heated O2 sensor, if anyone has a schematic and pin location for the wiring it would really help. Link to comment Share on other sites More sharing options...
James Matteu Posted March 13, 2008 Share Posted March 13, 2008 if anyone has a schematic and pin location for the wiring it would really help. You need the Honda Service Manual distributed by Helm, Inc. Link to comment Share on other sites More sharing options...
cranny Posted March 13, 2008 Share Posted March 13, 2008 obd1 honda civic pin location , color , function , (notes) A01 brown , injector 1 A02 yellow , injector 4 A03 red , injector 2 A04 orange/white , VTS(spool solenoid valve , Z1 and Z6 engines) A05 light blue , injector 3 A06 orange/black , HTCNTL(heated oxygen sensor(heater wire) , B7 , Z6 engines) A07 green/yellow , FLR1(power/main relay) A08 green/yellow , FLR2(power/main relay) A09 green/white , IACV A10 not used A11 orange/blue , ES(egr control solenoid valve , Z1 engine only) A12 yellow/green , FANC(fan control) A13 green/orange , WARN(check engine light) A14 not used A15 red/blue , ACC(ac compressor clutch relay) A16 white/yellow or pink , ACGC(alternator) A17 ATLSB(A/T solenoid , a/t only) A18 not used A19 ATLSA(A/T solenoid , a/t only) A20 red , PGS(purge cut off solenoid valve) A21 red/green , IGP1(ignitor) A22 red/green , IGP2(ignitor) A23 PG1(ground/main relay) A24 PG2(ground/mainrelay) A25 IGP1 yellow/black (power for sensors from main relay) A26 LG1 (ground for ECU) B01 IGP2 yellow/black(main power for sensors) B02 LG2 (logic ground) B03 ATD3(D3 indicator , a/t only) B04 ATD4(D4 indicator , a/t only) B05 blue/red , ACS(ac switch) B06 empty B07 CLSW(switched ground for M/T(clutch switch)) ; ATNP(park neutral indicator , a/t only) B08 brown/red , PSW(power steering pressure sensor switch) B09 white/blue , STS(starter signal/main relay) B10 yellow/blue , VSS(speed sensor) B11 CYP(cylinder sensor) B12 CYLM(cylinder sensor) B13 TDC(top dead center sensor) B14 TDCM(top dead center sensor) B15 CKP(crank position sensor) B16 CKPM(crank position sensor) D01 VBU - diagnostic trouble codes voltage(DTC) D02 green/white , BKSW(brake pedal switch) D03 LABEL(laf sensor , Z1 engine only) D04 brown , SCS(service check connector) D05 not used D06 orange/blue , VTM(vtec oil pressure switch , for D16Z1 and D16Z6 engines) D07 light blue , TXD/RXD(data link connector) D08 VS+(laf sensor , Z1 engine only) D09 white/yellow or pink , ACGF(alternator) D10 green/red , ELD(eld unit) D11 TPS - throttle position sensor D12 white/black , EGRL(egr valve lift sensor, for D15Z1 only) D13 red/white , TW(tw sensor , tied into data link connector) D14 white , heated O2 sensor(signal wire)(for B7 , Z6 , Z1((IP+ also)), engines) ; O2(non heated , for B8) D15 red/yellow , TA(intake air temp sensor)(ta sensor , tied into data link connector) D16 orange/black , IP-,VS-(laf sensor , Z1 only) D17 MAP D18 pink/green , SIL(shift up indicator , m/t) , white/red (interlock control unit , a/t) D19 VCC1(map sensor voltage wire) D20 TPS(voltage wire) D21 SG1(map sensor ground) D22 ground for IAT,ECT,TPS,and o2 sensors Link to comment Share on other sites More sharing options...
