Hatch92 Posted May 23, 2005 Share Posted May 23, 2005 i put a D16z6 motor into my cx hatch. there was no check engine light before the swap and now i have 1. what could it be? before the swap it was in an automatic EX would that make a difference because my CX is a 5-speed? if any1 else has so input let me know. Link to comment Share on other sites More sharing options...
redcoupe Posted May 23, 2005 Share Posted May 23, 2005 Is your SRS light on too? Wait... nvm. Change out your ecu with a manual p28. Link to comment Share on other sites More sharing options...
blackdelsol Posted May 24, 2005 Share Posted May 24, 2005 o2 sensor, maybe... Link to comment Share on other sites More sharing options...
Jap SiR Posted June 2, 2005 Share Posted June 2, 2005 Any one know why my engine management light comes on after i hit 100 mph on the road Cause im confused bout this, cause it happens every so often !!! Link to comment Share on other sites More sharing options...
CleanGSR Posted June 3, 2005 Share Posted June 3, 2005 I have a friend that had a 99 Civic SI with various mods including a VAFC or whatever the one for Vtec is called, and had it tuned on a dyno. The way they had it programmed it made the car run really rich over a hundred and made his check engine light come on. Well, that's the reason they told him that it came on at least......so don't know if maybe you are having a similar problem. Link to comment Share on other sites More sharing options...
