vannepoe Posted May 23, 2005 Share Posted May 23, 2005 Help ME!!!! please..... I have a dx hatch that was running fine then one day on the way home all the lights started going in and out in and out then the car started to die.... then suddenly it started working fine again..anyway after several conversations with the mechanic at the honda place here is a list of the thing i have checked/replaced: -master realy -altenator -starter -battery and ground cables -both fuse boxes (in cab, underhood) -pulled out dash harness checked every wire bleh it still doesn't work if anyone has a suggestion other than demonic posession, it would be awesome Link to comment Share on other sites More sharing options...
Jap SiR Posted June 2, 2005 Share Posted June 2, 2005 Dont have a clue what taht could be mate ! I thought mabey wires or summit or the battery but obviously not U got it sorted out yet ???? Link to comment Share on other sites More sharing options...
Speedy88 Posted June 2, 2005 Share Posted June 2, 2005 Take a look at your relays man.. that should do it Link to comment Share on other sites More sharing options...
EFHatchTuner Posted June 5, 2005 Share Posted June 5, 2005 My guess would be the alternator but youve replaced it so I have no clue. Good luck. Link to comment Share on other sites More sharing options...
blackdelsol Posted June 5, 2005 Share Posted June 5, 2005 it might not be electrical. Link to comment Share on other sites More sharing options...
Kastigir Posted June 5, 2005 Share Posted June 5, 2005 An engine needs three things to run. Compression, Fuel, and Spark. Check each one of these, and you should find your problem. Link to comment Share on other sites More sharing options...
