91H22Accord Posted May 20, 2005 Share Posted May 20, 2005 my driver side power window wont go up but all the other windows work fine i checked the fuses and they are all fine it happened before and i just added a little bit of oil lub and it worked fine idk what wrong with it this time ima take apart the whole door 2morrow if this has happened you before let me know Link to comment Share on other sites More sharing options...
tomegun Posted June 2, 2005 Share Posted June 2, 2005 This is another common problem with Accords. It is a good thing that you are doing it yourself. Honda will charge two hours of labor for this and you can do it in the same time. I don't know what year your car is but if you have a 96 it will help to use the holes in the door to loosen and tighten the window. Just roll the window up or down until the nuts line up with the holes. Link to comment Share on other sites More sharing options...
91H22Accord Posted June 2, 2005 Author Share Posted June 2, 2005 i took out the whole door and switchhed the motor that didn't work so i took off the panel where the buttons are and it seemed like the up button wasn't making contact with the switch so i had to hook everything back up and now it works fine Link to comment Share on other sites More sharing options...
dfaulkner Posted June 9, 2005 Share Posted June 9, 2005 glad you got it fixed, doing it yourself helps alot! Link to comment Share on other sites More sharing options...
91H22Accord Posted June 9, 2005 Author Share Posted June 9, 2005 yesterday the window fell off track again wat a bitch i think those aftermarket brackets suck i should of just gone to the junkyard and got a used one the new one i got isn't even the same size as the old one thatz y then window fell againg ohhwell ima try 2 fix it today its so easy since its like my 5th time doing it Link to comment Share on other sites More sharing options...
Arlorn87 Posted June 17, 2005 Share Posted June 17, 2005 Yeah...be glad your doing it yourself... the honda dealership just charged me ~250 to tear my doors apart and replace some actuaters... Link to comment Share on other sites More sharing options...
XScarAudio Posted June 17, 2005 Share Posted June 17, 2005 the doors are such a bitch to work in b/c its all sealed....thats why it costs so much. i've gotten MANY cuts working in the doors w00t Link to comment Share on other sites More sharing options...
CleanGSR Posted June 17, 2005 Share Posted June 17, 2005 Wish I had seen this post back in May... My old celica had that problem and the driver's window wouldn't go up. Got to looking and found out that the actual switch wasn't working, so got a new switch put in and it worked....sorry I didn't give advice any earlier. Link to comment Share on other sites More sharing options...
XScarAudio Posted June 17, 2005 Share Posted June 17, 2005 my pass side window goes slow....wonder if its the motor or the switch. i just haven't thought about it b/c it still works. Link to comment Share on other sites More sharing options...
Arlorn87 Posted June 17, 2005 Share Posted June 17, 2005 has anyone else had a problem with the window seals putting streaks on the inside of the window?.. my pass side has been doing that recently... Link to comment Share on other sites More sharing options...
Humphries Posted June 22, 2005 Share Posted June 22, 2005 it happens for me.. ALL THE TIME! all the windows go up at different speeds.. i have to put them all up seperately.. if i do them all at the same time, they all go slow and then i let go of one and the one im still putting up goes faster. it really pisses me off and i dont know what to do.. Link to comment Share on other sites More sharing options...
dfaulkner Posted June 22, 2005 Share Posted June 22, 2005 it happens for me.. ALL THE TIME! all the windows go up at different speeds.. i have to put them all up seperately.. if i do them all at the same time, they all go slow and then i let go of one and the one im still putting up goes faster. it really pisses me off and i dont know what to do.. slow windows are notorious on 94-97 Accords. Try taking off the door panels and spraying some silicone or WD40 on the track and connections, then run it up and down a few times till it loosens up. Link to comment Share on other sites More sharing options...
klevin Posted June 22, 2005 Share Posted June 22, 2005 Help! I've got a 2003 Honda Accord having window issues - been to BBB and now working with Lemon Law. Anyone out there dealing with this? Link to comment Share on other sites More sharing options...
