High Idle
h22turbo
about 2 days ago .. i took out my p/s components and cruise control.... now ever since then my car idles at 3k.. i would rev to 7k and then it would drop right down to 3k... i sprayed carb cleaner all over and found about 4 vacuum leaks... i plugged all of them up... and i also changed the pcv valve thinking it could have been that also but it wasn't what could this be.... thankx
is there a vacuum diagram there is i can use ??
  • 1 month later...
since you took off your power steering you are putting less of a strain on your engine, which lets it rev easier. all you have to do is turn down your idle screw and that will fix the problem. dont worry about it, it is perfectly normal.
