dcletten Posted April 12, 2005 Share Posted April 12, 2005 is getting an aftermarket intake manifold worth the money? more specifically is an OBX intake manifold worth buying? what would the gains be from it? Link to comment Share on other sites More sharing options...
CRG7 Posted April 12, 2005 Share Posted April 12, 2005 is anything obx worth buying? Link to comment Share on other sites More sharing options...
dcletten Posted April 12, 2005 Author Share Posted April 12, 2005 is anything obx worth buying? not really, just figured if MAYBE something from them would be, but are they, not obx in particular, i mean like venom, skunk2, etc. Link to comment Share on other sites More sharing options...
..SSR.. Posted April 12, 2005 Share Posted April 12, 2005 Only manifold I would get is the JG Performer X. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted April 12, 2005 Share Posted April 12, 2005 is anything obx worth buying? actually, OBX cams and diffs are not bad for the money at all. I'm sure OBX copied a design off of a proven HP adder. Link to comment Share on other sites More sharing options...
..SSR.. Posted April 12, 2005 Share Posted April 12, 2005 They copied Quaife's patented LSD. They copied someones cams (Skunk's I think). Boo. Link to comment Share on other sites More sharing options...
SexyH22 Posted April 12, 2005 Share Posted April 12, 2005 so is an OBX lsd as reliable as the qauife. cause i think quaife are lifetime warenteed. Link to comment Share on other sites More sharing options...
..SSR.. Posted April 12, 2005 Share Posted April 12, 2005 Nope. Material is a lesser quality, material is not finished correctly. Tolerances are off. You might get a couple years use out of one. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted April 13, 2005 Share Posted April 13, 2005 They copied Quaife's patented LSD.They copied someones cams (Skunk's I think). Boo. OBX isn't a company that wants to outperform anyone. they're out to make money. by letting someone else do all the R&D and then copy that design and sell the product for less is just what they do. Link to comment Share on other sites More sharing options...
arc man Posted April 14, 2005 Share Posted April 14, 2005 Well you need to specify what motor it is going on, well for about 50 bucks more you can go on ebay and get a skunk2 intake manifold but if you are running a b16 or 18 you could slap on a typeR intake manifold with really good powere gains, well I think for around 200 bucks you should see good throttle response, it will be noticeable but you might want to look into getting a bigger throttle body and see if you can fit a pretty big one but like they said for the money Venom not obx but it is your decision. I would do it Link to comment Share on other sites More sharing options...
BigBirdSucks Posted April 14, 2005 Share Posted April 14, 2005 Well you need to specify what motor it is going on, well for about 50 bucks more you can go on ebay and get a skunk2 intake manifold but if you are running a b16 or 18 you could slap on a typeR intake manifold with really good powere gains, well I think for around 200 bucks you should see good throttle response, it will be noticeable but you might want to look into getting a bigger throttle body and see if you can fit a pretty big one but like they said for the money Venom not obx but it is your decision. I would do it have you ever used an OBX manifold? if not, shut the fawk up. Link to comment Share on other sites More sharing options...
..SSR.. Posted April 14, 2005 Share Posted April 14, 2005 Well you need to specify what motor it is going on, well for about 50 bucks more you can go on ebay and get a skunk2 intake manifold but if you are running a b16 or 18 you could slap on a typeR intake manifold with really good powere gains, well I think for around 200 bucks you should see good throttle response, it will be noticeable but you might want to look into getting a bigger throttle body and see if you can fit a pretty big one but like they said for the money Venom not obx but it is your decision. I would do it You're a tool. ITR IM is not good for a B16. ITR IM should only be used on 1.8+. Skunk2 = not that great. Edelbrock, AEBS, AIR, custom = good An IM doesn't change throttle response generally. Link to comment Share on other sites More sharing options...
dcletten Posted April 14, 2005 Author Share Posted April 14, 2005 but say on a mini-me setup will it help at all? Link to comment Share on other sites More sharing options...
StanJenkins Posted April 14, 2005 Share Posted April 14, 2005 Link to comment Share on other sites More sharing options...
..SSR.. Posted April 15, 2005 Share Posted April 15, 2005 but say on a mini-me setup will it help at all? About 2hp. Link to comment Share on other sites More sharing options...
dcletten Posted April 15, 2005 Author Share Posted April 15, 2005 but i mean overall is the response better? is it overall worth the money, and what about a mini-me with a ported, polished, fully worked head, make it any better? Link to comment Share on other sites More sharing options...
..SSR.. Posted April 15, 2005 Share Posted April 15, 2005 Response does not change with a IM. Only way to change response is with a shorter intake or ITB's. Link to comment Share on other sites More sharing options...
