turbo
shadoe1998
who thinks it is a bad idea for me 2 get a turbo when mai stock engine has over 200,000 miles?
the car is a 1991 integra ls. or should i get a used stock engine and turbo what engine works best with the turbo (grs-ls-rs-gs? vtec? non-vtec)?
I would rebuild the engine no matter what.
1. No need to waste it by buying a new engine.
2. Even if compression is okay, it still isn't a good idea, parts get weaker over time, and it won't make as much power as if it was rebuilt.
  • 3 weeks later...
In laymans terms, you move a sand paper "cylinder" up and down while spinnging it in your cylinders to make a croos hatch pattern on the walls to make a quick ring seal. The cross hatch "sands" away the outside of the piston ring so they fit like a glove. Usually cost abot $10/cylinder.
