Something's blowing
Gsj
I have developed a noise around the throttle body/intake region. At first I thought it was my exhaust blowing as it is only when i accelerate that it is heard and sounds like this. Could anyone help me to identify what it is?
do you have an aftermarket intake? If so, check the sleeve-thingee on your throttle body, make sure the hose clamps are tight. Is the noise just your intake, uh, intaking when you accelerate? Also check your intake manifold, depending on what motor you have, the mani will have various rubber plugs in it, especially if you have a JDM motor that you've taken all the smog crap off of. Sometimes those plugs fall out, makes noise, and can mess with your idle. Hope that helps
