Transmission Q for 93' Sol Si
Ekarreinc
I just had put in a new radiator into my car. I was going to check my tranmission fluid level. But it seem to be missing the dipstick. So does a 93 Si comes with one? And if it does, what should be the corrent measurement level for tranmission fluid? It would be great if someone can help me with it, cause the closest honda dealership is 45 miles away, and I want to drive my car home for spring break without it broke down. Thank You guys.:thumbsup:
You have a transmission question and you don't even state what kind of transmission you have. Automatic/ Standard?
Most likely your vehicle is standard, so to check the fluid you would have to go underneath the car. Remove the transmission fill plug/bolt and stick your finger in the hole to see if you get fluid on your finger. The car should be level when checking the transmission fluid. Also the level of the transmission fluid should be level with the bottom portion of the transmission plug/bolt hole.
