A 97 cl vtec question--help if possible
the only thing putting a resistor on the solenoid would do is let less voltage get to the solenoid. The VTEC system is all inside the ECU, making adjustments to the engagement RPM requires the use of a VTEC controler or proper computer tuning by a qualified company.
