bcivic Posted April 15 Share Posted April 15 2001 civic a2 engine I start car from cold run it to hot drive 30min no problem runs like it always had shut it off for hour and start it it runs for a couple minuets then goes into a "limp" mode it doesn't have a miss but doesn't have power and wont hardly idle i can shut it off and 10 to 15 minutes later it drives fine again during that time fuel pressure is same and proper i pulled o2 sensor out and it ran same I cleaned egr same changed throttle ass which included 4 sensors idle air throttle position sensor and 2 more same running compression all same and good swapped all 4 coils from running car same running issues i changed cam position sensor i think thats it Quote Link to comment Share on other sites More sharing options...
