Jayeffel Posted January 19 Share Posted January 19 On my 2002 Honda CRV I am having problems. First, the button on the drivers door near the inside door opener that I think is to lock and unlock all doors does not work for any door. Second, the drivers door lock/unlock button does not work. Third, the key when attempting to unlock the divers door sometime works, some times not. now and then it gets stuck. I checked all fuses and they look good and show continuity of current. I looked inside the drivers door panel and saw no connector loose. I have not yet taken the whole panel off to see if anything obvious is wrong. Would I be expecting the driver's door actuator to be bad, but would that cause all other doors to not lock/unlock? I probably need a new door lock mechanism for the driver's door. Would a connection go bad? If the weather cooperates enough I need to check to be sure all linkages are in place. Quote Link to comment Share on other sites More sharing options...
