Posted
Hello,
I am new to these boards, please forgive me if I am posting in the wrong forum.
I have a 2016 Honda CRV Touring and everytime I start my car I get a bunch of warning lights on. Dealer near me is charging an arm and a leg to just diagnosis so any help would be appreciated!
Warning lights:
Check ACC System
low brake fluid
check TPMS System
check vsa system
check hill start assist system
check power sterring system
chck cmbs system
check acc system
low brake fulid
check ldw system
  • 2 months later...
Posted
Do they just show up and then turn off, or do they stay lit? Of they disappear quickly I would say there is a self test and they passed.
There are testers you can get to tread the codes yourself.
  • 2 weeks later...
Posted
Hey Jayeffel,
They stay on the entire time, so as I turn the car on they stay on throughout my car rides. Most car dealerships are charging so much just to check. I've had this issues for a few months and I am looking for any advice!
Posted
You can get a scan tool - or a phone  app such as ODD Fusion (free) or CarScanner ( they don not tell you it costs) and check the codes and even erase the codes. Once erased they may disappear which indicates the problem may now not exits, or come back which would incite a sensor detects something wrong. The tool plugs into the meter at the dash, the apps connect via Bluetooth.
I have seen where several people merely replace the sensor, it may be be bad, but usually points to something between the sensor and what it is to warn you of.
For instance something about the exhaust being bad would be before the sensor, not after it.
Posted (edited)
On 1/22/2023 at 4:32 PM, palifalcon said:
I wasn't able to find either of those apps in the app store through iphone, could they go by different names?
Sorry OBD Fusion is one, Car Scanner May be the same company. I forgot one major part!  The OBD Fusion will as well last there other  other one, uses a plug in device you keep in the code reader port. You can monitor the engine as it runs if you know what you are looking at- I merely checking the speed and current estimated fuel usage.
To merely read a reset the codes a plug in meter will suffice, make sure it works with your vehicle. The package it comes in (Wally World, auto parts, online)should let you know which.
Edited by Jayeffel
grammar error
