BrianM Posted June 11, 2021 Share Posted June 11, 2021 Experts, I have a 2011 Honda CR-V, 112,000 miles, Original owner, no accidents. Everything fine except drivers door lock unsuccessfully trying to lock over and over. Aware of Honda door actuator problems. Replaced front drivers door actuator and now that door works fine, but NOW my rear tailgate would not open. its just not getting the signal that all of the other doors are unlocked. I replaced the tailgate lock assembly, but same problem, the signal to unlock is no longer getting to the tailgate. Tried reprogramming keys several different ways. Does the new actuator need to be introduced to the MICU? Tried removing fuses for MICU and also rebooted car by disconnecting battery for ten minutes. no luck yet...Is there a connection? Thanks, Brian Quote Link to comment Share on other sites More sharing options...
