beardguy48 Posted August 17, 2020 Share Posted August 17, 2020 I recently bought a 93 del sol and I want to swap the trans and engine to make it a manual with a dohc vtec engine can someone help me out? Link to comment Share on other sites More sharing options...
Drucifer616 Posted November 27, 2020 Share Posted November 27, 2020 On 8/17/2020 at 10:37 AM, beardguy48 said: Ok... so I've done several of these... make for sure you use all del sol stuff or your gonna Can be to cutom build stuff... Del sol b16 shift linkage bc Integra or civic wont work. Make sure the engine harness is del sol as well only bc they are differnt idk what anyone says... the delsol is its own car you can use your shifter in the shift linkage bc again delsol is differnt lol Other than that all you need is a b seiseries engine and trans if your car is manual already just get the b series engine mount kit. EDU, wire up vtec if yours isn't already, b series axles and your goid from there. On 8/17/2020 at 10:37 AM, beardguy48 said: Link to comment Share on other sites More sharing options...
Drucifer616 Posted November 27, 2020 Share Posted November 27, 2020 On 8/17/2020 at 10:37 AM, beardguy48 said: If your car is auto... then Ooof! But Hasport make a mount kit for going from auto to 5 speed but your gonna need a ton of other stuff for that not to be cutting it short but if you dont know what else you need for a auto to manual conversation then just don't please . Quote Link to comment Share on other sites More sharing options...
