Supra_Spooler Posted February 19, 2020 Posted February 19, 2020 Hey guys, Newbie here. First off, this is for my daily 05 Honda Accord. Here is my issue below: Compressor kicks on with AC button - I can hear it running Both high and low sides are ambient temp with compressor on, not cold or hot. Gauge for high read 20 PSI Gauge for low reads 0 PSI I'm reading conflicting answers, so I'm just looking for most likely cause. Part of me is thinking maybe it's a clogged expansion valve (how common is this?) Also, I replaced the block-shaped fuse to the a/c system as a starting point..no dice. Thanks guys.
Jeff Papineau Posted February 20, 2020 Posted February 20, 2020 For me, it was the block shaped Relay in the fuse box of the eng compartment, fixed my AC. Was glad it was not the compressor. $10 relay
Supra_Spooler Posted February 20, 2020 Author Posted February 20, 2020 Whoops, yes I replaced that relay, not a fuse. I messed up in my original post. It didn't fix anything for me.
