SolSearching Posted October 24, 2019 Share Posted October 24, 2019 i'm not getting power to my fuel pump. when i turn on the ignition my wipers turn on so i'm wondering if there is a connection . all fuses are good. this problem began slowly. i'm doing some body work and i'd pull it out of the garage to work on it and it began to start very hard but eventually would start but eventually it refused to start. so i replaced the relay switch and fuel pump which needed to be done anyway so no big deal. so i checked the power to the pump and no power. is this an ECU issue? thanks! Quote Link to comment Share on other sites More sharing options...
