EJ7lowlow Posted March 6, 2019 Share Posted March 6, 2019 I had heat then next day it's only blowing like warm coolant levels are perfect Quote Link to comment Share on other sites More sharing options...
drewusmaximus Posted March 19, 2019 Share Posted March 19, 2019 You might have air trapped in the system. Try bleeding the system with the heat turned to high. Not sure if you have a bleeder screw but, if you do, run the car to normal temp, then open the bleeder screw carefully to release pressure. It's ok if some coolant comes out. Actually you want coolant to come outwith a consistent flow. If coolant comes out with bubbles, there's air in the system. Quote Link to comment Share on other sites More sharing options...
