TxCivic2885 Posted June 18, 2017 Share Posted June 18, 2017 New to the forum.... Just replaced the transmission in a 2004 Civic. JDM tranny. Since I did that I change and top off the fluids. After doing so I noticed after a couple drives the fluid in the brake cylinder reservior was green. So I attempted to flushed the lines and only the front would flush. I am getting no fluid to the rear drums. I changed out the proportioning valve under the master cylinder and got the same result. Now the valve was from a junk yard due to I am on a budget. Any suggestions? Anybody dealing with this or have dealt with this. Link to comment Share on other sites More sharing options...
HondaPartsConnection Posted June 20, 2017 Share Posted June 20, 2017 Are you using a flushing tool or just opening the bleed valves? Link to comment Share on other sites More sharing options...
