valve adjustment?
iceberg
The ONLY way to really know if the engine valves are out of adjustment is to remove the valve cover and check the clearances manually with a feeler gauge. Id youtube it.. im sure theres a lot of videos showing you how its done. By the way... the engine should be COLD when doing this proceedure to get the best valve clearance measurements.
Hope this helps a little.. :)
