Pnaps801 Posted April 14, 2017 Share Posted April 14, 2017 1991 Honda Civic hatchback DX so I have changed the fuel pump it's working not fuel lines not clogged either is fuel filter but still won't start relays and fuses checked and are good tried hitting with a little bit of ether in the carburetor wants to start gets the closest but still won't What's next guys? Link to comment Share on other sites More sharing options...
Aggressor5 Posted April 19, 2017 Share Posted April 19, 2017 1. Turn the ignition switch ON (II), and watch the MIL. • If the MIL doesn’t come on, or it comes on and stays on, see the electronic service manual . • If the MIL comes on for two seconds and then goes off, go to step 2. 2. Check for battery voltage at the positive wire going to the coil, and at the positive wire going to the ICM. • If you have battery voltage, go to step 3. • If you don’t have battery voltage, check for an open between the ignition switch, the ICM, and the coil. 3. Connect a voltmeter between the coil negative terminal and ground, and record the cranking voltage two ways: first with the wire between the coil and ICM connected, then with it disconnected. • If you get about 8 V with the wire connected and 10 V with it disconnected, install a new coil, and retest. • If you get about 10 V with the wire connected and disconnected, install a new ICM, and retest. Link to comment Share on other sites More sharing options...
Pnaps801 Posted April 23, 2017 Author Share Posted April 23, 2017 What's the MIL? AND THE BATTERY HAS BEEN DEAD SO I HAVE BEEN TRYING TO JUMP STARR IT Link to comment Share on other sites More sharing options...
Aggressor5 Posted April 24, 2017 Share Posted April 24, 2017 Hello MIL stands for Malfunction Indicator Lamp or check engine light. It usually looks like an engine or wrench. Try putting a new battery in it. The weirdest of issues can be caused by the most simple things. Link to comment Share on other sites More sharing options...
Pnaps801 Posted April 24, 2017 Author Share Posted April 24, 2017 I got it recharged from AutoZone and there is no check engine light it stays on to prime pump then goes off ECU reads 1 flash for 02 sensor that the wire was pulled apartment Link to comment Share on other sites More sharing options...
Aggressor5 Posted April 25, 2017 Share Posted April 25, 2017 Do you have spark? Link to comment Share on other sites More sharing options...
Pnaps801 Posted April 26, 2017 Author Share Posted April 26, 2017 Yes sir brand new plugs and dizzy is spinning Link to comment Share on other sites More sharing options...
