washer fluid not spraying
  • 10 months later...
Clear the nozzle. Clear the clogged nozzle with a pin, then use compressed air to blow the debris backward through the hose. If you hear the pump going but don't get fluid, you probably have clogged nozzles. Lift the hood and trace thewasher hose from the nozzles back to the reservoir.
