GRN-BNDT Posted July 29, 2015 Share Posted July 29, 2015 In my 1994 Del Sol Si automatic, it sometimes won't shift out of 2nd gear upon starting from park. Usually when I start moving it makes this scrape sound and will shift, but other time it'll stick in 2nd and make a high pitched sound as it revvs up to high rpms. Usually when it does this, if I make a complete stop and sit for a second and start going again, it'll make the scrape sound and start shifting, but other times it doesn't. It's harder to make it start shifting when I have to first back up like down a driveway or out of a parking space. I'm thinking it's not the transmission itself, because when it does shift, it shifts really cleanly. Perfect fluid level, tested the upper shift/lock up solenoids, they work. What could be causing this? Is there another solenoid to test or is it a problem with the TCU? Please help! Link to comment Share on other sites More sharing options...
smoothmover Posted August 11, 2015 Share Posted August 11, 2015 The issue may be caused by a broken internal spring found in the automatic transmission gear. Link to comment Share on other sites More sharing options...
