oemhondaparts Posted October 9, 2013 Share Posted October 9, 2013 i parted a few cars a while ago and the parts below are whats left. the list is updated and these are the only parts i have left. i sell on ebay but with the fees i am looking for alternatives. i have a paypal account thats secure to send payments to or if you would like to meet up i live in sacramento, ca. make me an offer for whatever you need. the prelude was a 93 h22 vtec, the civic eg was a 94 d15 and the del sol was a 93 d16. email norcalaudi@hotmail.com or call 707-363-0520 prelude parts: front brake calipers l,r stereo housing rear license plate bezel set of 4 turned brake rotors glove box steering wheel a/t shifter complete front seat belts l,r front bumper support rear bumper support driver window passenger window trunk lid door driver door passenger door rear bumper exhaust downpipe h22 and h23 moon roof assembly complete vtec body wiring harness half shaft counter shaft for axle hood open prop rod side skirts clock spring for steering wheel hood hinges door open max stoppers passenger window motor trunk release cable fuel door release cable seat belt buckle rear center steering wheel position sensor flexible brake lines to calipers all 4 heater coolant flow control valve hood open prop rod blue or black trunk latch cruise control steering wheel buttons mirror position switch light dimmer switch cruise control on/off switch sunroof open/close switch door position switch passenger window switch horn buttons blower motor blower resistor e brake lever cruise control unit power steering reservoir brake master cylinder wiper motor clutch slave cylinder door lock actuator l,r fuel rail h22 coolant thermostat housing with ect ignition cable, blue harness abs control unit srs control unit a/t control unit cruise control unit srs impact sensors license plate lamps & bulbs interior door handles l,r fuel door blue or silver driver exterior door handle in blue exterior door handles in silver l,r complete a/c system, every part to run it headlight housing l,r torque converter del sol parts: ignition switch tumbler trunk hinges l,r fuel door brake master cylinder interior fuse box dash fuse cover window position switch clutch fluid reservoir defrost switch door position switch horn speaker fuel door release cable rear speaker covers l, r front brake calipers l, r hood open prop rod window washer reservoir fluid pump motor heater coolant flow control valve master window switch clutch slave cylinder side skirts l, r passenger window driver window passenger door dash in excellent shape civic eg parts: ashtray, change, lighter housing 1.5l intake manifold interior complete fuse box under hood exterior complete fuse box flexible brake lines fl, fr srs control unit interior dome light lamp right door lock actuator rear center seat belt and buckle e brake lever right door speaker cover side door mirror glass l, r clutch slave cylinder door position switch ignition switch tumbler fuel cap driver airbag passenger airbag hood prop rod horn speaker hazard switch Link to comment Share on other sites More sharing options...
Rajah Ghany Posted March 8, 2015 Share Posted March 8, 2015 Hello how are you . do u still have the passenger door to the 92 Honda prelude? Link to comment Share on other sites More sharing options...
Daniel Longoria Posted October 16, 2015 Share Posted October 16, 2015 I need front bumper and driver side fender 92 prelude Link to comment Share on other sites More sharing options...
