forevermemorable Posted September 24, 2013 Share Posted September 24, 2013 I installed a re-manufacturer starter into my car, but I noticed my ground wire was broken (it was that way when I purchased the car used, 3 years back). And this is probably why my starter went bad to begin with.I would hit the old starter solenoid with a mallet every now and then, to get the car starter...but you can only do that so many times. At any rate, I replace the starter and the car turns on just fine. I am ordering OEM part through the mail. After a week, the car starts to giving me trouble starting specifically from the starter. Not the battery, because it was just purchased brand new. I am 99% confident the reason the new re-manufacturer starter I installed is giving me trouble was because of a lack of ground. And then my car ceases to start at all. Actually, I heard the starter trying to turn the car on and it was almost going to turn on, but than the car dies and I have not been successful in getting it to even rev or rum, rum. I have also replaced the negative cable with a new one and still, my starter will not kick my engine on.Without a grounding and running my car for a week, could I have shorted my starter? I checked all fuses and relays in the engine and they are all functioning. I have also checked all fuses under the car dash (driver side) and they are all functioning. Maybe there is a missing relay I missed? My first thought is short somewhere, but I am not sure where. I guess my next step is to replace starter again and see if that solves the issue.What do you think? Link to comment Share on other sites More sharing options...
James Matteu Posted September 24, 2013 Share Posted September 24, 2013 I think if your negative cable was in such poor condition, it stands to reason your positive cable is no good either. Link to comment Share on other sites More sharing options...
forevermemorable Posted October 9, 2013 Author Share Posted October 9, 2013 Problem solved! I watched numerous You Tube videos about testing electronic components. I did a voltage drop test, I checked continuity, I rechecked components, relays, etc. Nothing showed anything wrong; however, I watched a You Tube video that said you must have a minimum of 12.40 voltages on your battery. My battery tested at 12.39 (only 3 months old)...I return battery to Costco and they told me that my Odyssey took a bigger battery (with more cranking amps). That figures...that last place sold me the wrong battery. I was hoping that this discrepancy would have solved my car not starting...it did not. After all of the tests performed, I was left with the last resort...replace the starter I just installed a month prior. After the replacement...car starts up just fine. I guess we will see how long this will last for. Well, at least I learned a lot about testing with a voltage drop meter and a multi-meter. Link to comment Share on other sites More sharing options...
