Jackel0808 Posted August 21, 2013 Share Posted August 21, 2013 I have a 2000 honda civic. I also have 1000 dollars to put into it. I just recently bought the car and haven't done anything to it. It has 138k and is super clean, most likely reprinted. The car came with an oem intake, aluminum radiator, and is lowered, with springs. I want either power mods or handling mods. I don't like ricer shit either. If it was yours (possibly you have the same thing and it is yours) how was you spend that money on the car? Thanks Quote Link to comment Share on other sites More sharing options...
James Matteu Posted August 22, 2013 Share Posted August 22, 2013 I'd use the money to change the timing belt, replace the MTF, change oil, distributor cap, dist rotor, spark wires, air filter, spark plugs, brake pads, flush the brakes, flush the coolant, directional soft compound tires, put some gas in it and call it a day. Humphries 1 Quote Link to comment Share on other sites More sharing options...
Jackel0808 Posted August 22, 2013 Author Share Posted August 22, 2013 That's all been done. It's clean and very well taken care of. Quote Link to comment Share on other sites More sharing options...
James Matteu Posted August 22, 2013 Share Posted August 22, 2013 How are you sure what maintenance has been done? Just and enjoy! Humphries 1 Quote Link to comment Share on other sites More sharing options...
Xeryon Posted August 28, 2013 Share Posted August 28, 2013 If $1000 is all you have and ricey shit is out then you are SOL. You can't do anything productive with that little money. Sure there are things you can waste your money on but $1000 isn't enough to get all the things your would need to realize any improvement in performance or handling. Quote Link to comment Share on other sites More sharing options...
