Invictus.TheIdleKing Posted August 6, 2013 Share Posted August 6, 2013 My Honda Accord stalled out at a stop sign. I have replaced the ignition control, distributor, spark plugs and cables, checked the order of them. Now when attempting to start it tries to start... there is a low rumble from the exhaust; however, it doesn't start. I verified that there is fuel pressure and spark as well. I am double checking the spark gaps tonight. Any other ideas? What else can I verify or replace? Quote Link to comment Share on other sites More sharing options...
James Matteu Posted August 7, 2013 Share Posted August 7, 2013 Can you get it started and maintain idle with the accelerator? Quote Link to comment Share on other sites More sharing options...
Dani Mari Posted August 18, 2013 Share Posted August 18, 2013 Possible fuel pump failure. Quote Link to comment Share on other sites More sharing options...
Dani Mari Posted August 18, 2013 Share Posted August 18, 2013 Use an obd scan tool. Quote Link to comment Share on other sites More sharing options...
Jeff Collision Posted August 20, 2013 Share Posted August 20, 2013 Does the car ever seem to run properly? Also, check to ensure that you are getting the proper amount of flow from the fuel pump and that the fuel filter is not clogged.Does the car ever seem to run properly? Also check to ensure that you are getting the proper amount of flow from the fuel pump and that the fuel filter is not clogged. Quote Link to comment Share on other sites More sharing options...
