Electrical problem with passenger window
malhindi11
My front passenger window will work by the passenger button switch (Up/Down) perfectly. But when I try to put the window up from the driver main block/switch, it does not work. The window will go down when I hit the passenger button from the driver switch block but it will not go up. I have tried cleaning the connections and that usually speeds up the motors but it did not work this time.
Any ideas as to why this is happening
Not a motor problem 'Jeff Collision'.
"My front passenger window will work by the passenger button switch (Up/Down) perfectly."
Not sure what OP wanted from us, she/he identified a potential cause, made a temporary repair to the switch which confirmed same, then the temp repair failed which would indicate the switch still needs to be replaced.
Edited by James Matteu
