honda AC not working loose wire hanging connector?
see
I have a 2001 honda accord which recently the ac stopped working. what I"ve found so far w/ friend:
-no voltage to compressor. works fine when we jump battery voltage to compressor
-relays are fine because we switched it out w/ other relays
-fuses are good check fuses
now I did notice a wire harness connector hanging loose on driver side but can't seem to find where it connects to. Lost key a couple days back and had to get locksmith to cut and reprogram key (guess thats where he had to plug into, to get programming. Can that loose connector be the cause of it and where does it plug into?
