xc3ssive Posted June 27, 2013 Share Posted June 27, 2013 Hey guys I'm looking for some insight before I actually take my car to a repair shop. This is whats going on. The car is really hard to start without pushing the gas pedal down a couple of times then it has a rough idle but goes to normal AFTER it's blown a huge amount of white smoke from the exhaust that was a weird smell, does not smell burnt tho. Also while I'm driving the temperature of the car fluctuates from 1/2 way to cold to RED. I'm freaked out because I don't know what the issue seems to be. It just started like a week ago. Any help or insight is greatly appreciated. Thank you Link to comment Share on other sites More sharing options...
Xeryon Posted June 27, 2013 Share Posted June 27, 2013 White smoke in the exhaust is commonly caused by the burning of anti-freeze. Check your coolant and your oil to find if there is any mixing of the two fluids. When they mix they usually form a dark-ish milky coloring. You may be dealing with a damaged head gasket. The hard-start can be a symptom of a blown gasket that hasn't blown out enough to be inoperable but just enough that there isn't enough compression to start correctly. The wild temp fluctuations are another tell-tale sign as well. There are other possibilities but start by checking those fluids and we can go from there. Link to comment Share on other sites More sharing options...
