danyeungw Posted June 25, 2013 Share Posted June 25, 2013 When the machinist told me the price for replacing the timing belt whole unit, does it mean it is more than just the timing belt itself? What does the whole unit include? Thanks. Danyeung Quote Link to comment Share on other sites More sharing options...
Xeryon Posted June 25, 2013 Share Posted June 25, 2013 You did not specify your vehicle year or engine which might change this info a little. The default for a 4cyl Honda timing belt service should include the timing Belt (Honda OEM if possible), timing belt tensioner, water pump, water pump gasket. There are other optional service items I like to do at the same time: thermostat and cooling system flush and new AC, PS and Alternator belts. When the water pump is replaced you loose a little coolant as well as maybe getting some debris in the system and now is as good a time as any to have that service performed. The belts all have to come off to get to the timing belt anyway. There should be $0 in labor to have them replaced as taking them on and off is part of the normal service process. Quote Link to comment Share on other sites More sharing options...
James Matteu Posted June 25, 2013 Share Posted June 25, 2013 Also might be a balancer shaft belt involved. Quote Link to comment Share on other sites More sharing options...
danyeungw Posted June 26, 2013 Author Share Posted June 26, 2013 (edited) Thanks. Do you have to pay addition for thermostat and cooling system flush and new AC, PS Alternator belts, and balancer shaft belt? It is 2003 Accord V6. Edited June 26, 2013 by danyeungw Quote Link to comment Share on other sites More sharing options...
Xeryon Posted June 27, 2013 Share Posted June 27, 2013 Depends on what the mechanic meant when he said "timing belt whole unit". You will need to ask him. At a minimum it must be TB, TB Tensioner, WP and WP gasket. If it isn't then you need a better mechanic. Quote Link to comment Share on other sites More sharing options...
