Honda Aspire
MRLAW18
I had this car sitting in my front yard for about 3 years now so i think its time to make it a project car.....Given tht i'm a college student cash flow will be minimal so for now i will go for a sleeper style look.....
WELL TODAY i TRIED STARTING IT BUT NOTHING, I ONLY HEARED A LOUD CLICKING SOUND COMING FROM THE ENGINE. scettico.gif . I CHECK THE PRESSURE OF THE FUEL PUMP IN THE ENGINE AN NO PRESSURE IN IT, WORSE THE ENGINE WASNT EVEN TURNING... I DID SOME CHECKS AND PULLED THE STARTER SOLENOID TO DO SOME SERVICING
whoaa bro... the stones were temporary... the tools were in the truck and my pops was @ work... the mechanic was gonna leave before my pops got home so we had to do with what we had... we were just takin a look on the bottom half of the engine.
ok.... now i've reached a dead end... need some tips... need some help interms of how can i clean the engine without fully dismantling the engine,....
i think oil has found its way in the piston chamber... how can i get it out like i said before without dismantling the engine.....
#I'm in school so this is a budget build
How much oil? Where is it coming from?
The piston rings are open and should allow oil to drain past if left to sit. You can always add a solvent to speed that process.
Honestly, removing it would be a minor concern as firing the engine up should burn small amounts of oil away. If you're talking about a large amount of oil, then a more important concern is from where and why isn't it draining.
I've added a solvent to the oil but i'm gonna let it sit there for a while cause it cuts away the gunk build up slowly.... i haven't checked it as yet to see if its working....
In the last pic above you see the where i lifted the engine cover and the Rocker arms are covered in oil that has been settled for about a year or so i tried scraping it off and i realize it peels .... Can u recommend a simple way how to clean it????
... So far i don't have a clue where the oil is coming from but it's a small amount though... gonna make a small video and post it as soon as i can... Right now i haven't tried starting the engine cause obviously there is some small amount of work needed to be done before doing so......
Edited by MRLAW18
If its a small amount of oil, leave it alone.
Oil in the valve train is normal. You're going to do more harm than good. Changing the oil often will clear most of the residue on the rocker arms, but really I can see what youre dealing with and I've seen much worse. Leave it alone and get this motor started.
SO, today i did a lil bit of cleaning in the engine, removed the radiator but the oil cooler got damaged during the process, used a torque wrench and turned the crankshaft bolt and i hear compression building and releasing.... :hyper::frantics: So thats a good sign that the engine might be able to turn over and all piston will be firing....
Radiator with damaged oil cooler
View with radiator and intake tube gone
So today is gonna be slow cause this is my brain storming period... Found A great sample of what im going for.. i knew i said i wanted a sleep style but this is nice too.... after the engine upgrades i'll choose based on the cash i have left
