vic Posted April 30, 2013 Share Posted April 30, 2013 I have a 94 civic dx 1.5 l automatic. I can start it up put it in drive or anyother gear and it works fine.for a few minutes. the it runs through first and second but will not up shift to third. when this happens it will no longer take any gear until I turn off the ignition and restart. Then the same type situation. up shift solinoids? Quote Link to comment Share on other sites More sharing options...
summer Posted May 1, 2013 Share Posted May 1, 2013 yes ,you just try Quote Link to comment Share on other sites More sharing options...
Cuba Rodriguez Posted May 1, 2013 Share Posted May 1, 2013 It could be a variety of internal trans issues.... gears, steels, clutches, solenoids, or shafts....sometimes if you drop the trans pan, it can give you a better clue. Like if you find metal shavings, probably more mechanical failure... or if you find no shavings more common the solenoids may be bad. Either way start looking for a trans or options on rebuilds vs junkyard, etc good luck Quote Link to comment Share on other sites More sharing options...
