Trepid Posted May 30, 2002 Share Posted May 30, 2002 ok, I have a pair of 12's in my trunk and I recently noticed that when I balance right the speakers hit but when I balance left they don't. I looked at them and they both seem to be working but don't know if that is just an effect of the air moving a non working sub. If this is a problem it has been there since I had the subs installed. am I crazy or what? Link to comment Share on other sites More sharing options...
0verb00st Posted May 31, 2002 Share Posted May 31, 2002 how do you have them hooked up to the amp? you should have them bridged mono. Link to comment Share on other sites More sharing options...
Trepid Posted May 31, 2002 Author Share Posted May 31, 2002 Not really sure, I had circuit city do it Link to comment Share on other sites More sharing options...
0verb00st Posted June 1, 2002 Share Posted June 1, 2002 that could be a very bad thing. theyve been known to mess up a lot of cars. you should rewire it bridged mono. what subs and amp are they? Link to comment Share on other sites More sharing options...
Trepid Posted June 10, 2002 Author Share Posted June 10, 2002 Rockford fosgate Punch's and a JBL 600 amp Link to comment Share on other sites More sharing options...
0verb00st Posted June 10, 2002 Share Posted June 10, 2002 i believe the JBL 600.1 is stable to 2 ohms mono (make sure you check first to be sure). your subs are 4 ohm SVC. this means you can wire them in parallel @ 2 ohms mono. not only will it sound better, but you will gte more power out of your amp so you can play your subs much louder. Link to comment Share on other sites More sharing options...
XScarAudio Posted June 10, 2002 Share Posted June 10, 2002 is the amp bridged or stereo? here's a couple of things to test first of all 1. switch the rca's on your amp and see if the situation reverses. it is very easy to cut an rca doing a quick install. 2 if it doesnt change the situation, and you're in stereo, swap the sub/channel and try again. that will let ya know if its an rca or a blown channel or a sub. Link to comment Share on other sites More sharing options...
0verb00st Posted June 10, 2002 Share Posted June 10, 2002 i just realized what my last post said. there is no way you could have the 600.1 running in stereo. it's a monoblock amp. so either circuit city really messed up (running the signal off one channel), or your amp is stereo. if so then it should still be wired mono. but it is probably only 4 ohms mono stable. that means you should wire the subs in series to make an 8 ohm mono load. wire one sub's + terminal to the amp's + terminal (bridged. it will be labeled on the amp). then the - on that sub to the second sub's +. then the second sub's - to the - on the amp (and make sure it is the bridged -). Link to comment Share on other sites More sharing options...
