anthony916 Posted December 28, 2012 Share Posted December 28, 2012 Im getting mix info on the topic would like to hear what everyone thinks. Will a turbo be safe and reliable on a b20/vtec? The car/motor is relatively stock besides the head. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted January 7, 2013 Share Posted January 7, 2013 no. if you want safe and reliable under boost you're going to need pistons, rods, balanced crank, and you will also need to sleeve the block.. cylinder walls on a B20 are too thin to handle boost above 10 - 15psi.. frankenstine builds arent relatively reliable to begin with and adding boost will just be an added headache without doing supporting mods to help the engine be more reliable Link to comment Share on other sites More sharing options...
..SSR.. Posted January 7, 2013 Share Posted January 7, 2013 If you keep it in the 180-200whp range with a good tune it will be reliable if the engine is in good shape to start with. Reliable is subjective when it comes to anything to is built, especially turbo setups. Link to comment Share on other sites More sharing options...
jdmYolo9902 Posted January 10, 2013 Share Posted January 10, 2013 not very reliable unless you do the works or at least some... normal oem pistons and stuff usually wont hold boost very good till they give or cause problems Link to comment Share on other sites More sharing options...
..SSR.. Posted January 10, 2013 Share Posted January 10, 2013 Yes they will as long as the power is kept relatively low and the tune is good so there is no detonation. Link to comment Share on other sites More sharing options...
