2001 Civic Making Ghastly Death Noises
seamonkey
Short video of the noises
http://www.youtube.com/watch?v=_MRfBjGuQJY
Storytime:
sound appears to be emanating from the driver side of engine compartment, nearby the belts.
was not making noises, then suddenly this horrible noise started when i started the car.
no obvious problem with the belts. they seem tight and relatively fresh
oil level looks good
alternator looks beat up and old
OBD code P0440 (gas cap code) has been triggering the check engine light for a while now
My questions:
What are the likely causes of such ghastly noise? What can I do about it?
Edited by seamonkey
The code P0440 is associated with Evaporative Emission Control System Malfunction and could mean one or more of the following has happened:
The gas cap is not installed or working properly
The purge solenoid has failed
The canister is plugged and not working properly
This indicates that a part of the EVAP control system is no longer functioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. It is recommended to check with automotive experts soon.
