eddiem4 Posted December 7, 2012 Share Posted December 7, 2012 i have a 1988 honda civic dx hatch that wont turnover. it tries to but wont start. i pulled all 4 spark plugs to see if there was a problem there and all 4 were oil soaked. can anyone help me out with this? what could be the problem and why is there oil covering all of the plugs? Link to comment Share on other sites More sharing options...
iamandy Posted December 31, 2012 Share Posted December 31, 2012 idk if im right but i had a problem just like this for my 91 accord with a f22 i pulled the plugs knowing where then went. then i got a full head gasket kits, which came with new grumets for my plugs, it was simple to do this kit a little oil and some wrenches and about 2 hours. after i did the kit i leaked no oil and i stopped getting oily pistons. you should look into it. what type engine you got? i ask a couple friends see what they say Link to comment Share on other sites More sharing options...
Humphries Posted January 23, 2013 Share Posted January 23, 2013 is the oil in the spark plug hole on the top side or on the combustion side on the electrode? it's either spark plug tube seals (replace valve cover gasket kit with tube seals) or bad rings Link to comment Share on other sites More sharing options...
StrapOnTech Posted February 15, 2013 Share Posted February 15, 2013 new plugs Link to comment Share on other sites More sharing options...
Joe Rini Posted August 2, 2013 Share Posted August 2, 2013 Take the plugs out clean them with brake clean pull the valve cover off and seal the spark plug gaskets with hightemp rtv silicone and ull be good to go. Just had this happen the other day and this is just a quick fix to get it running. Untill u replace the valve cover gaskets Take the plugs out clean them with brake clean pull the valve cover off and seal the spark plug gaskets with hightemp rtv silicone and ull be good to go. Just had this happen the other day and this is just a quick fix to get it running. Untill u replace the valve cover gaskets Link to comment Share on other sites More sharing options...
