charcoalburner Posted November 23, 2012 Share Posted November 23, 2012 In addition to the starting issue in another post, I have also been having an issue with stalling on this same van. When i accelerate to about 40-45 mph the van will start to shake and sputter, I will immediately let off of the accelerator and it will stop. At this point I can then continue to accelerate and it will work just fine. My dealer said it was the EGR valve and I replaced that but the problem is still happening. Any ideas? Link to comment Share on other sites More sharing options...
Jeff Collision Posted December 7, 2012 Share Posted December 7, 2012 I have heard of people having this same problem with Honda Odysseys—it could be a transmission problem. You’re right though, it also could be as simple as replacing the EGR valve. The only way you’re going to know for sure is by taking it to a mechanic and having him run a diagnostic test. The code you get will tell you if it is the EGR Valve. I really hope it’s not the transmission. Link to comment Share on other sites More sharing options...
